Get Unlimited Text and 100 mins of Talk for $15
03-15-2019 09:10 AM
Starting March 15th, we’re excited to bring you something that’s been long requested- a new Ready-Made plan at $15 with Unlimited International Text. This plan is available for new and existing customers and includes:
- 30-day plan
- 100 minutes of Canada-wide Talk
- Unlimited International Text and Picture Messaging
- +Bonus 250 MB with AutoPay
- Voicemail and Call Display
How to Get This Offer:
New customers |
Current customers |
-Public Mobile Community Team
FAQ
Question |
Answer |
What does and does not use my minutes? |
Will you notify me when I’m almost out of minutes? |
Yes, you will get an SMS message from Public Mobile when you 10 minutes left in your plan. |
If I don’t have any minutes left, but I have a voicemail message, how do I check my voicemail? |
There are two ways you can check your voicemail.
Do I have to purchase a Long Distance Add-On to get more than 100 minutes? |
Yes, you need a Long Distance Add-On to get more minutes added to your plan. If you often use more than 100 minutes per 30 days, we recommend one of our plans with unlimited talk. |
If I purchase a Long Distance Add-On, will my calls use up my Add-On minutes or my in-plan minutes? |
If you purchase a Long Distance Add-On and you’re calling in Canada, your call will use your in-plan minutes first. If you purchase a Long Distance Add-On and you’re calling outside of Canada, your call will use your Long Distance Add-On minutes (as long as the location you’re calling is accessible through your Long Distance Add-On). |
Will I keep the same plan forever? Will my plan change? |
Please refer to our Terms of Service for more information about our plans. |
05-20-2023 02:20 AM
@hTideGnow wrote:HI @pm-smayer97 one of the most asked question. Yes, incoming calls is still unlimited, not sure why PM still not add it back to the plan details for $15
It seems a pattern for many months where PM does not advertise available plans and features, and are only visibile AFTER you sign up, for example, there are many more 4G plans available via self-serve not on the PM Plans page. 😕
05-19-2023 11:31 AM
05-19-2023 10:52 AM
Never mind... I found how to answer my own question... when you go to Self Serve and select to Change Plans, pull up the $15 plan and it lists that "Unlimited Incoming" is part of the plan.
05-19-2023 10:36 AM - edited 05-19-2023 10:37 AM
@softech wrote:
How To Access Your Voicemail From Another Phone:
- Call your 10-digit phone number.
- When you hear your voicemail greeting, press the star key (*) to interrupt it.
- Enter your voicemail password when prompted.
- Follow the voice prompts to listen to your messages
That is the simplest. Of course, if you do not want your phone to ring, you can call any of the VM access numbers directly. Yours can be found in your phone settings OR see:
You will then be prompted to enter your phone first, then the rest is the same.
05-19-2023 10:29 AM - edited 05-19-2023 10:30 AM
@dabr wrote:@PeggyC ...
Also, hopefully you're on the second version of the $15 plan that includes unlimited incoming and not the one under discussion here which was only available for a few months before being upgraded to the current version.
I am confused by the current $15 plan. PM does NOT advertise that it comes with unlimited incoming. When I asked CS_Agent about this, they claim it still comes with unlimited incoming BUT because it is not advertised, I am not sure if this is true or not.
Can anyone validate that the CURRENT $15 plan (vs any previous version/iteration of this "SAME" plan) STILL provides unlimited incoming, even though it is not advertised with that feature?
05-19-2023 09:41 AM
05-19-2023 09:38 AM
Hi, what are the steps to check VM using another phone? Thanks. (sorry if it has been answered before.)
05-18-2023 06:13 PM
hi @PeggyC yes, checking voicemail from your own phone on a $15;plan will cost you outgoing minutes. So, either use another phone to check VM or use VOIP app like Fongo or TextNow for checking VM
05-18-2023 03:40 PM
@PeggyC Yes if you're on the $15 plan then retrieving voicemail will deduct from the 100 outgoing minutes unless you use another phone to access voicemail, of course.
05-18-2023 03:33 PM
Do you mean when I retrieve my message, it counts the talk time (deduct from 100 mins Canada-wide Talk?
05-01-2020 11:24 AM
Thanks, I'll check it out.
05-01-2020 12:08 AM
Thanks, looks pretty good at least for the first 3 months.
04-30-2020 08:56 PM - edited 04-30-2020 08:56 PM
Look into mint mobile (part-owned by Ryan Reynolds now) they offer 3 month plans starting at $15/4gb per month with free calling and texting to Canada and Mexico. They regularly put promos on and if you have a dual SIM phone it will be easy to manage both lines. You can still recieve incoming texts on your pm phone without a roaming add on....some say incoming calling still works as well.
04-30-2020 08:11 PM
@JohnnyXI Try it. It's free. Just keep your number active by using it once a month. I have sent texts and made calls from my home and it works well from there. I haven't tried outside over data. My internet is with Fido and it's 75/10 mbts. Stay safe.
04-30-2020 08:04 PM
Re Textnow, never heard of them. I do however have magicjack another VOIP service which I pay for bur have foud it to have poor quality audio, drops calls and worst of all, sometime tells caller that my line is out of service. Any comment on Textnow service?
04-30-2020 07:59 PM
@JohnnyXI Check Amazon they sell prepaid SIMs that work anywhere in NA for calls, texts and data.
04-30-2020 07:52 PM
I did buy a U.S. sim card with U.S. Mobile but unfortunately they have no service or add on at all that allows access to Canada. Plus people are whining about having to manage two phone numbers, one while in Canada, one while in the states, for me. So I'm looking at Base $15 + 3x$8 (for 30 days talk) = $49/month (no text). Getting a bit expensive so maybe I'll look around.
04-30-2020 02:17 PM
@JohnnyXI wrote:Excellent, Thank you.
You can get a free voip app like TextNow that will let you make calls and text while you have a wifi signal. You can make/recieve calls to US / Canada for free as well as text.
There's free wifi in alot of places in US so this might work for your requirements.
04-30-2020 02:15 PM
Au contraire....you need a working plan for your roaming add on to work as you do with every canadian provider. If you have no service on your phone roaming cannot work. If you dont want to pay for your service just suspend at the end of your 30 days (before renewal) and purchase a US sim/travel sim and plan. When your finished travelling pay and unsuspend (before 89 days) your pm account.
04-30-2020 02:13 PM
04-30-2020 02:10 PM - edited 04-30-2020 02:12 PM
04-30-2020 02:08 PM
Thanks, kinda obvious I suppose, although disappointing, given that it's of no use when I'm in the U.S.
And 2) does the U.S. add on 'plan' include talk to Canada?
04-30-2020 01:29 PM
@JohnnyXI wrote:I have a Cdn plan. So when I go to the U.S. and get the U.S. Talk and Text Bundle
Unlimited Talk and International Text for just $15 for 10 days can I let my Cdn plan expire or do I have to keep it active?@JohnnyXI You need to keep it active2) Does the U.S. T&T plan allow calls to Canada?Yes both calls and texts.
04-30-2020 01:28 PM - edited 04-30-2020 01:28 PM
@JohnnyXI Hello yes you can call back to Canada from the US but you do need to keep your Canadian $15 plan active
04-30-2020 01:25 PM - edited 04-30-2020 01:31 PM
04-30-2020 01:02 PM
06-09-2019 01:18 PM
@coffee wrote:
@LovesToPM wrote:
@TheOldVR wrote:
@coffee wrote:PM should send a notice to Walmart - The Walmart in Cobourg gave me a hard time trying to steer me away from PM and go with Lucky instead. In fairness it was not all sales persons at their electronic section but just this older woman that seemed to be the supervisor.
Did they have a valid reason?
The Walmart salesperson sells many providers so they might have been trying to look out for you?
Hmmmmm. I wish Walmart wireless salespeople would look out for their customers.
If this were the case, she would have told @coffee to go Dollarama across the street and get a SIM for $4.
Does Dollarama sell PM Sim cards or are you just being facetious?
Dollarama sells the other brand. Exclusive partnership announcement
I believe she was steering you towards Lucky, correct?
06-07-2019 10:38 PM
While I do know that Dollarama does sell SIM cards for certain carriers, I didn't think they were currently selling Public Mobile SIM cards. Maybe they are now?
06-07-2019 10:37 PM - edited 06-07-2019 10:41 PM
@coffeeSome do out east depending on where you are. I would say Lucky provides more support than PM, then you miss out on a few bucks off via autopay, community participation etc... you trade that off but get 1800 #, phones and stores etc.
06-07-2019 10:36 PM
