CAN-US-MEX $29 per mo.
Dahveed
It is a little confusing with the description of this plan.
CAN-US-MEX  $29 / mo.
It says:
  • 5G Speed
  • 20GB Data
  • Unlimited Talk & Text
  • 100 International minutes
  • $1.45/mo. in Public Points
  • PROMO: Chance to win a trip to Mexico
When I check the Terms and conditions (Unlimited Talk & Text2), it noted – “ Unlimited Canada-wide minutes include calls made and completed within Canada. Roaming applies outside of Canada. Long distance rates apply to calls made from Canada to outside Canada. ”
Nothing related to the Unlimited Talk & Text  as above.
If I subscribe to this plan, my questions are:
  1. Can I call/text USA or Mexico while in Canada at no costs?
  2. Call/Text Canada if I am in USA or Mexico at no costs?
  3. Would my data work in USA and Mexico?
Thank you.
DennyCrane
You're looking at generic terms and conditions which cover all plans. You need to match the specific term numbers to the subscript numbers identified on the plan in question. Not all terms apply to all plans.
Phil_Adelphus
@Dahveed   I don't know why it says long distance rates apply for calls to outside of Canada, there are no extra charges with Public Mobile as it is prepaid.  To call outside Canada the country needs to be one that is included in your plan, or you need to buy an add on if there is one for that country.  It doesn't affect your questions though.
One caveat for voice calls when you are in the USA is that you need a phone that is approved for VoLTE by Public Mobile as there are no more 3G networks in the USA.  Approved phones are on the list in this link, and any newer versions of these phones would be presumed to work also
https://www.publicmobile.ca/en/on/get-help/articles/volte
Dunkman
Thank you.
@Dahveed
Yes, to all three of your questions.
