Subscription Upgrade
11-22-2023 07:27 PM
Should I choose to upgrade my subscription,
a) Will any rewards applied to my subscription still be there?
b) Will the two $2 discounts still apply every month?
Add-Ons
My Account
Rewards
11-22-2023 08:25 PM
@cschuber1 That's correct! You will not lose your discounts unless you opt for the new points system.
Do not opt for that if you want to keep your previous discounts. There are very minimal advantages to the new points rewards system compared to the previous legacy rewards system!
11-22-2023 08:25 PM
Hi @cschuber1
yes, after a plan change, you still on the same rewards system and you will get the same rewards discount.
11-22-2023 08:21 PM
This is true. I suppose I could have worded the question better. As the account is in good standing and always has been, the same or similar discounts would apply then. Is that correct.
11-22-2023 08:00 PM
Yes, the rewards will still remain. The discount is applied based on your account's standing, not based on plan selection.
11-22-2023 07:33 PM
all Rewards as well as any gifted Add-ons will still be yours to use whenever you want. Just never..I mean ever opt for Points instead of Rewards. 😁
11-22-2023 07:29 PM
a) Yes. b) Yes.
![](/skins/images/02B49C0B2FC614613D221373CF8AAEF5/responsive_peak/images/icon_anonymous_message.png)
