5G subscription with 4G phone data speeds
Xopher
i have a 5G subscription plan & am currently using a 4G phone. Assuming I can only get 4G speeds, which is fine for the moment. What should my 4G speeds be. I'm thinking 50 Mbps max & usually 30Mbps on average according to speedtest.net is a bit low. Any insight. Thank you.
1 REPLY 1
slusagm
The 5G plan is just about speed.  A 4G phone on 5G plan can still get close to the top speed promised for the 5g plan, 250Mbps
But it depends on phone. Yours is not a North American phone so the bands might be an issue for getting better speed.  but try Reset Network Settings and maybe it helps
