02-16-2025 12:10 PM
When I log in I get the message "Your services are on hold due to the expiration of your subscription. If your services are on hold for more than 90 days, your account will be closed permanently and you'll lose your phone number"
I have auto pay set up and my card is not expired.
Service
02-16-2025 12:14 PM
try login My Account again using Incognito mode and it will show the correct info
and check credit card
02-16-2025 12:12 PM
@Erinm1234 wrote:When I log in I get the message "Your services are on hold due to the expiration of your subscription. If your services are on hold for more than 90 days, your account will be closed permanently and you'll lose your phone number"
Sometimes the system can send faulty errors. Is your phone working though? You can make and take calls? Text and data works? If so, you can ignore this message.
02-16-2025 12:12 PM
hi @Erinm1234
it could be just a browser cache problem. Please try again using Incognito/private/secret mode on your browser to login My Account, or try using the PM app (logoff the app first and log back in)
if same, then submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
