02-16-2025 11:55 AM
Do I have to register for the rewards program or can I just hit redeem by the reward I want
02-16-2025 12:15 PM
@Happygirl62 wrote:Do I have to register for the rewards program or can I just hit redeem by the reward I want
Hello @Happygirl62
You are automatically signed up for the points system. Here is the lnk. Click on "Visit My Rewards" and it will take you to the secondary site.
02-16-2025 12:13 PM
Once you created an account and activated a SIM, you are registered.
Depending what you want to redeem. Click on Rewards tab>Browse Catalogue and pick the reward you want once you have enough points. I normally go for the $15 credit with a minimum of 15 points.
02-16-2025 11:58 AM
hi @Happygirl62
don't have to register for Rewards. The Rewards program comes with your account setup
Login My Account, click Rewards on the top right and you can go to the rewards portal to check how much you have. Yu can redeem any there as long as you have enough points
