01-21-2023
11:55 AM
01-22-2023
10:34 AM
Dunkman
looked at all replies about this very topic and says click envelope.When I do so it says do not reply
" go to community"
"Send private message"
Its not very clear how to simply navigate to send private message
My time is valuable this page should be made easier to navigate.
Thanks to all that can help me.
01-23-2023 10:07 AM - edited 01-23-2023 10:12 AM
@computergeek541 @hTideGnow these private messages are not ours to own. Private messages generally are not private if telus/public mobile (companies) have reason to monitor or review or shut down, etc. Its 'their' forum.
Just like my work emails are not my own.
01-22-2023 09:10 PM
Thanks to all that so kindly replied.I now figured it out ( after of course your help) and just waiting to get a reply and resolution from Public Mobile.
Thanks to all I so appreciate all help that I received.
01-21-2023 10:24 PM
Extremely remote as past history indicates that I have personal history with so my statement is true for all intensive purposes and does come from the top. If they cannot access private messaging then no one can barring a court order perhaps?
01-21-2023 10:15 PM
@darlicious wrote:Your private messages can only be seen between you and the recipient and vice versa. However do not stay signed into the community if your device can accessed by someone else, on public wifi or while using a public computer like at a library. Treat your community account security the same as your self serve account.
Public Mobile cannot access the content of your private messages other than the ones you send back and forth with customer support.
I wouldn't be so sure that Public Mobile can't access private messages between members. Nothing is really private on the internet and someone at Khoros or Telus could certainly gain access, although I would think that occassions of that being necessary (or allowed) would be remote.
01-21-2023 08:15 PM - edited 01-21-2023 08:15 PM
01-21-2023 01:37 PM
Hopefully - trying to capture the left vs right brain thingee.
Re the OP exclaiming their "time is valuable", it's likely they believed they were offering that info to Public Mobile staff, not other customers on this forum.
Our time is clearly not as valuable as the OP's. We only make $0.05 - $0.15 per hour.
01-21-2023 01:29 PM
great use of graphix. Hopefully, should clear things up for our busy OP.
01-21-2023 01:25 PM - edited 01-21-2023 01:26 PM
@Member wrote:Thanks : my issue is I received a message and need to reply , but can not locate anywhere in
community that says send private message?
its not showing anywhere send private message?
Any suggestions on it?thanks
See this picture. On yours which is top right, tap the envelope icon. From within that page, you can read and send messages to the CS_Agent group.
To send a message to them, tap the area with bolded background:
Then in the "Send to" field, type the @ button, then begin typing CS_Agent. Select the result that shows a bolded CS_Agent result.
Then in the "Message body" field, start typing your message to them.
When you're done, send the message.
01-21-2023 01:05 PM - edited 01-21-2023 01:09 PM
@Member Did you happen to have some back and forth conversation with an agent and accidentally delete it , and now here you are ? If that’s the case you may have to start a new ticket
edit or are you thinking you should have a private message cos SIMon sent you here
01-21-2023 01:00 PM
01-21-2023 12:55 PM
01-21-2023 12:53 PM - edited 01-21-2023 12:57 PM
01-21-2023 12:35 PM
01-21-2023 12:26 PM
You're looking at an email notification notifying you of the fact that you got a private message. Then yes you come here to reply to it.
If your time is so valuable then maybe this place isn't the right fit for you. Are you like a sole-owner of a privately held multinational company or something? That's valuable time. If not then you're on the same value of time as all working people even if you own your own business. Your time ain't that valuable.
01-21-2023 12:25 PM
HI @Member Private message is between you and the other party. Of course, very likely PM can see all your private messages, just be aware.
If you need to private message CS agent for help, you can use this link:
The link is the same as sending message to CS agent in this profile:
https://productioncommunity.publicmobile.ca/t5/user/viewprofilepage/user-id/22437
01-21-2023 12:19 PM - edited 01-21-2023 12:21 PM
watch the little envelop icon, top right side of page will be highlighted when they respond.
added,
what's the issue ...maybe we can help or provide further guidance.
01-21-2023 12:14 PM
thanks for your quick reply.Yes I have a ticket and reply, but it says " do not reply to this message"
"Go to community and use private message"
It really ought to be made easier. Thanks again will look further into. your recommendation .
01-21-2023 12:03 PM - edited 01-21-2023 12:04 PM
Send a private message to the CSA - agent by clicking (Ctrl+)Here
OR to send PM to other customer, click on his ID and on top right corner:
01-21-2023 12:01 PM
@Member you have a problem with PM service and need to open ticket with PM? Maybe you are share and we can help. If only workarounds needed or how to use, we can reply much quicker than PM Support
But if you need to open ticket, please use Chatbot if possible. You can also private message using Method 2 below. The private message is to send to CS Agent, which is private between you and PM:
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
01-21-2023 11:57 AM - edited 01-21-2023 11:59 AM
