11-13-2023 01:06 PM
11-13-2023 01:17 PM
To a degree you are correct. However when it comes to using 911, it's best to have the correct address on profile in case you're unable to speak. Yes they can triangulate your phone location but they can also contact Public Mobile for a direct address on file in case of emergencies.
11-13-2023 01:13 PM
Hi @kellisha2
This can happen sometimes due to your browser cache issues. For now, the system has locked you out from doing any changes. So please wait just over 1 hour. Then go into your browser settings, clear the cache, close the browser and log back in and try again. If you're still unable to change it because perhaps your postal code isn't registering correctly, you can reach out to a CS Agent to help change it.
To contact a Customer Service Agent, please click on the following link.
Please be sure to keep an eye on the top right corner where you’ll see this icon show up.
11-13-2023 01:11 PM
Address does not matter. You can have there anything.
You are charged based on your area code not address.
11-13-2023 01:10 PM
* log in to your account on a laptop using incognito mode. * Make sure the postal code is correct.
11-13-2023 01:10 PM
Hi @kellisha2
What address are you talking about? Do you mean the billing address on your Credit Card?
