Where can I pay my phone line
jessi8413
 in GEORGETOWN-HALTON HILLS AREA...
8 REPLIES 8
darlicious
@jessi8413
Read this post for up to date info on vouchers and other methods of payment....
https://productioncommunity.publicmobile.ca/t5/Get-Support/Can-t-Make-a-Payment-or-Update-Your-Card-...
However you can mosey on down Mountainview Rd and purchase pm vouchers at 7/11 or Shoppers Drug Mart or the PetroCan Station. On Guelph St you can buy vouchers at customer service at stupidstore (lol...RCSS) there's another Shoppers Drug Mart. Walmart is YMMV and unless crappy tire has a gas bar for RTP their vouchers bought at customer service can have up to a 24 hour delay for validity. Every other retailer mentioned is immediately valid and loadable via 611 on your phone.
Yummy
You can pay your PM bill in 3 ways no matter where you are located:
- Setting up autopay - credit card has to be registered with PM; bill will be paid every 30 days
- Manually, logging on to your PM account with CC registered with PM (but autopay not set up)
- Buying a voucher and either through My Account or calling 611.
@jessi8413 on top of My Account, voucher, you can also pay via Instant top-ups
Instant top-ups are currently available at most Canadian Tire Gas, Esso, Gateway Newstands, and MacEwen locations.
There is certainly a Candian tire gas in Georgetown:
https://www.google.com/maps/place/Canadian+Tire+Gas%2B/@43.6500295,-79.8914218,17z/data=!3m1!4b1!4m5...
and a Shoppers Drug Mart is right next to it if you want to get voucher from there.  Getting it from SDM is good as their vouchers can be used immeidately
hairbag1
@jessi8413....
to pay using on-line vouchers, go to www.recharge.com of ding.com.
Voucher number sent to you right away after paying, then dial 611 to add them to your regular plan renewal.
Be aware..they do have a small user fee.
Best practice is to register your credit card on your account, then enable Autopay. You won't have to worry about vouchers after that.
@jessi8413
PM is done all online so you need to login to your account. You can use CC, debit or vouchers.
You can purchase a voucher from these locations and dial 611 and enter your voucher number:
Quigley
@jessi8413
Sorry but you can only pay by doing it yourself online or by calling 611 from your mobile phone.
Just login to your My Account.
CGO
online via self-account or autopay.
HI @jessi8413
best way is to login to My Account and pay there.  Can you login ?
 If not, try to Reset password or open ticket with CS agent:
at : https://publicmobile.ca/chatbot.
First type Forgot Login,
You can also pay by *611 if you already have a credit card setup on your account.  But you need your 4 digits PIN if you are paying that way
Or you can get a voucher from store in your area.  Check Shoppers drug mart or gas station like Shell.   When you have the voucher, pay by *611, you don't need 4 digits PIN for loading voucher
You can also get voucher online from recharge.com
