12-08-2022 01:13 PM
Can a MOD please message me? I'm trying to activate a sim and it won't accept any of my credit cards
Joining Public
Payment
12-08-2022 01:28 PM
Just try a little later in the day and try using a different device like a computer or laptop instead, like I suggested before.
12-08-2022 01:26 PM
@RedDotBaddie wrote:I have tried a visa, MC and a debit Visa. Nothing is working
that is weird.
Maybe try again on another device, maybe desktop or laptop
If still unable to activate, either wait till tomorrow or message PM CS agent and see if they can confirm if there is problem on the system
Message them here:
12-08-2022 01:25 PM
Activating a new sim, yes
12-08-2022 01:24 PM
12-08-2022 01:22 PM
Try doing your activation on another device like a computer or laptop instead of your mobile phone.
It makes a difference sometimes.
Try again on other device.
12-08-2022 01:22 PM - edited 12-08-2022 01:22 PM
HI @RedDotBaddie and you are activating new account on PM , right? you are not trying to replace a new sim card on an existing PM account?
12-08-2022 01:20 PM
HI @RedDotBaddie you might need to try a different card.
may i know which is the issuer of the card? and it is Visa or MC?
12-08-2022 01:18 PM
They are CDN cards. I haven't been charged. I have used both incognito and regular browsers. Nothing has worked so far to activate 😞
12-08-2022 01:15 PM
HI@RedDotBaddie sorry, PM is all self managed 😞
So, is the credit card a Canadian or US one? you cannot use overseas credit card on PM
also, before you try again, confirm PM didn't charge your card yet
When you are ready to try again, I suggest you to try using a different browser or even use Private/Incognito mode. This could solve your problem.
and make sure you put in the correct postal code and name used on the credit card
