Activated
Mimi2611
How would I know that I purchased e sim?
@Mimi2611
if you have only used the browser to subscribe, but didn't use Public Mobile app at all, your subscription was not completed.  Please download Public Mobile app from app store and login and complete the rest of the activation process
Mimi2611
Thank you so much but I didn’t start step one Idk how
Mimi2611
Can please go over steps to change to esim
@Mimi2611
Did you use the Public Mobile app and got to Step 6 to complete the subscription?  If so, the app would have installed the Public Mobile eSIM for you.
You can also confirm the eSIM is there and is properly enabled.
On Android:  Check your Sim Card Manager and see if a Public Mobile eSim is there.  If so, make sure it is enabled.
On iPhone: check Settings > Celluar and see if the eSIM is there.  If it is, make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on
if you don't see the Public Mobile esim there, check the Welcome email, there should be a QR code for the esim for you to scan and install manually.  If you cannot find it in Inbox of your email, check also the Spam box.
If the Public Mobile eSIM is there, disable or delete those non PM sim (eSIM/Physical sim).
If the non-PM sim is physical, remove it.  If the non-PM sim is an esim, disable using the SIM Manager on the phone (or set as Secondary and turn off "Turn on this line" for this non-PM esim)
Then reboot the phone and click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
If it still does not work, you will need to have PM support to further assist.
PM support for further assistance.  Please open ticket using Public Mobile Expert Messaging using your Community/EverSafe account.  Select Start a Chat to begin:
          https://expert-messaging.publicmobile.ca/guest/pre-chat
**You'll get email/SMS alert when agent replies. or monitor here: https://expert-messaging.publicmobile.ca/message-centre
** If you cannot receive 2FA code via SMS and unable to open ticket, please use another email to setup a new Community account and DO NOT link a phone number to it.  You can then create an Expert Messaging ticket using that new account.
