01-08-2025
11:10 AM
01-08-2025
05:09 PM
computergeek541
Hi, I'm on an e-Sim card and I am wondering, can I use a micro memory card in it's place for extra memory on my phone ? Sadly, my cell apparently doesn't have a spot for adding extra memory cards... thanks for any info I can get on this... Darlene
01-08-2025 11:34 AM
Actually, if I ordered a Sim card instead of using the eSim, and my contact transferred onto the Sim card, would open up memory space on my phone ? I have a Galaxy S24 FE
01-08-2025 11:25 AM
ok.. thanks
01-08-2025 11:17 AM
hi @DarleneI
only work if you have one of those dual sim phone from Asia. The 2nd sim slow can be used for micro sd card. But if yours not one of those, then sorry, no
01-08-2025 11:15 AM
the hard sim slot is for a sim...not gonna work for memory card. You might even break something...don't try it.
