01-08-2025
12:06 PM
01-08-2025
05:00 PM
computergeek541
Hi! I subscriped to a plan with esim only to find out in the App that my phone does not support eSims. I bought a physical Sim card but have no clue how to change the plan and activate that card.
01-08-2025 02:13 PM
Hi,
When you log-in to the app, does it display an option to go back?
01-08-2025 12:19 PM
Well I am not sure... I log into the App and it asked me to activate subscription but I can not do that - because I opted for the eSim. I don't see an Account option
01-08-2025 12:08 PM - edited 01-08-2025 12:09 PM
@DoroC first step is you need to have the Public Mobile app installed on your phone to complete the activation which should set up your SIM
From the app, go to the "Account" tab, then select "Change Your SIM card"
