05-31-2026 10:46 AM
I wanna open an account and try to active a physical SIM card which was used by my MOM before. She just switched the physical SIM to eSIM today. However, during my new account activation, the error "Invalid SIM card Number, plz try again." was showing.
05-31-2026 11:32 AM - edited 05-31-2026 11:32 AM
You can order one from Canadian Cell Supplies for $5 and once you have the new SIM. Login to her account then to Account tab-Change Your SIM Card to transfer her account to the new SIM…including her number.
05-31-2026 11:30 AM
@jadonlu710 wrote:Is it possible my MOM would use this SIM card again if she wanna physical card for the same phone number?
Or is my Mom's physical SIM card completely useless now?
The used SIM card is completely useless now.
05-31-2026 11:16 AM
05-31-2026 11:00 AM
Can my Mom still change back to this physical SIM or not, even the same phone number?
05-31-2026 10:57 AM
hi @jadonlu710
you cannot reuse an already used sim card.
so, you need to buy one. Buy it from a Telus , Koodo or Mobile Klink store for $10
05-31-2026 10:52 AM
Hi @jadonlu710
Sadly, once a SIM card with Public Mobile has been used, it's no longer valid with any other account or plans.
Here is how you can get a new one.
To get a new SIM card the fastest routes are these.
https://www.publicmobile.ca/en/bc/pick-up-SIM - Find a local store in your area.
Amazon - Here you can get it cheaper and maybe a few days wait $9.99
Or find a Mobile Klinik near you. https://mobileklinik.ca/stores/
05-31-2026 10:49 AM
SIM card is one time used. If it was used by your mom before, it cannot be reused for a new account
you have to buy a new one. Buy a new Public Mobile sim from Telus or Koodo or Mobile Kilink or Amazon
