05-31-2026
05:20 PM
06-08-2026
10:28 AM
Dunkman
I purchased the esim plan and it told me my phone was compatible with esim but after downloading the app and trying to get the esim on my phone it said it wasn't compatible so is it possible to get a refund and just order a physical sim? or what should i do?
05-31-2026 05:26 PM
I sent them a message waiting for reply now.
05-31-2026 05:22 PM
yes, it is possible. Either PM can send you a eSIM QR or they will ask you to buy a physcial sim from store and they will update the sim card number for you. But please ask PM first by opening ticket and they will advise
Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
