Usage History Downloads - random snippets - not following applied filter
umnikke8
Tried to gather up my Usage History Download for last month, it doesn't seem to work properly anymore. It gives me some random snippet of time when I download it, looks like about a week, not the full range of the currently applied filter. When I tried again, I got a different time range.
19 REPLIES 19
John-Q-Public
It was my post, and the link within it, that was deleted.
Twice! 😡
@John-Q-Public wrote:
Correct.
Thing is, I violated NO terms of service, that I know of. (check out what wrote, at the supplied link; If you find something, I'd like to know!)
When I clicked on the "appeal" link, and explained the situation, I got no reply.
BTW, sorry to have replied to your reply 🙂. My reply was intended for @on2wheels .
The violation to the terms of services was by a different member.  That's why there was a link earlier in this thread that was inaccessible.
John-Q-Public
Correct.
Cheers,
 -Paul
Hi, @on2wheels
Unfortunately, that link got nuked by PM (no explanation given).
I just posted a reply to it, with another link. Hope it helps!
As I was saying earlier, the message contained in the link isn't supposed to be accessible.  The contents were removed due to a violation of the terms of service of this website.
John-Q-Public
Hi, @on2wheels
John-Q-Public
Replying to myself, hopefully to keep inline with the thread... So, it looks like PM deleted that post again, so I posted again... 4 months and change later, it seems to have held, so I'm posting its link here. Hope it helps!
Usage History download truncated: a Workaround - Community (publicmobile.ca)
umnikke8
It's been broken the same way for quite some time, I don't think anyone is doing anything to fix it.
on2wheels
Does anyone know if this usage history glitch is still being worked on?
@on2wheels wrote:
Is this feature still being worked on? It's not working today either (the download usage bug).
That message isn't supposed to be accessible. It is only a note that action was taken due to violation of terms of service by a another member.
on2wheels
John-Q-Public
Take heart, Usage History Glitch Sufferers!
I have proposed a workaround here:
https://productioncommunity.publicmobile.ca/t5/Get-Support/Usage-History-issue-a-Workaround/m-p/1051...
Hope this helps!
EDIT: PM nuked it again, no explanation. Try this:
John-Q-Public
For cryin' out loud, PM, how hard can this be??
PLEASE, fix the usage download! It's ridiculous how long this, and other issues, take to fix!
(P.S.: I have been in IT for four decades, and am knowledgeable in programming and websites.)
DUGGS
I can't view anything before June 2nd.
As well the helper people keep telling me to follow your instructions. Haha
@DUGGS
At the moment, download Usage history is sort of broken, just 2 or 3 days usage from the XLS download.  But you can still go through each page on the Usage history on My Account for up to 3 months of usage. You will need to copy and paste manually for now
DUGGS
I'm having this same issue. I need a month at a time for my P.O. and I've been trying to get last month's for since the 1st
Grinch
Nor can you select or filter SMS, talk etc.
@umnikke8   basically usage download is broken  😞
the original usage download was designed to download the full history, not following the filter.
But since the update, the full usage download has became just 3 days download only.  I have tagged agene and Jade on another post, they are aware of the issue, but not sure when they will have that fix:
https://productioncommunity.publicmobile.ca/t5/Announcements/We-want-to-hear-from-you-technical-conc...
@umnikke8 yeah, I noticed the download didn't work for me a week or so ago. I just gave up at that time, in hopes it was 'being worked on'.
