01-28-2022 01:55 PM
Not sure if I'm the only one but good thing I went into the my rewards portal as I was looking to see if I should change or not. It showed my loyalty monthly amount but my auto pay was at $0 so I went into my account and saw that my auto pay was turned off so I'd recommend going into your account and checking if your auto pay is active. With this new rewards program that started on January 25th 2022 for me the grandfathered plan I save alot more and so it's worth checking to make sure your grandfathered rewards are active before your next top up.
01-28-2022 01:56 PM
01-28-2022 01:59 PM
HI @foreveryeg Thanks for the head up .
Yes, not getting the Autopay $2 discount is one thing, without Autopay and account got suspended would be a bigger issue, a disaster.
01-28-2022 02:10 PM
Great heads up post! I'm going to check my accounts now....
01-28-2022 05:57 PM
Much appreciated! Checked account, all looks good.
01-28-2022 05:58 PM
@hTideGnow wrote:HI @foreveryeg Thanks for the head up .
I would not call it disaster as there is remedy for suspended account, as you know 🙂
But it will be big PITA for sure...
