Cellular data
BeachyBrandi
My husband and i have been having trouble with cellular data. I have an iphone and he has an andriod. Yesterday we both could not get on the internet or use any aps. And the same this is happening today.  Turned off and on airplane mode as well as the cellular data. Works for a few minutes and then cuts out.
Any ideas????
Thanks
139 REPLIES 139
hi @LexiLou29
are you in Manitoba?  Not sure if you are impacted
https://productioncommunity.publicmobile.ca/t5/Get-Support/Active-Degradation-in-Manitoba/m-p/144112...
But check Telus outage map
https://www.telus.com/en/bc/outages
Also, try Reboot phone and click Reset network settings
@Wayneasmith
use the app to log in to your Public Mobile account and see Usage Breakdown. It'll show you current plan details.
Try restarting your cell...then try a network re-set to see if data starts up.
hi @Wayneasmith
make sure you don't have mobile data limit enabled
try reboot phone and click reset network settings first
if same, then submit a ticket with CS Agent using Chatbot here:
             Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
LexiLou29
My son says his data cuts out when he leaves the house 2 days in a row so far, and sometimes the service cuts out at home for no reason. He has same plan as us, and a good phone. Restarting his phone will help but that's a hassle. Any advice?
Thanks,
Lisa
Wayneasmith
  • When month renewed my data stopped working
JeeminMoon
It's actually working now. Thanks for your advice!
JeeminMoon
I'm in Cambridge, ON. I've tried reboot and reset network settings, but it still doesn't work.
HI @JeeminMoon
JeeminMoon
Hi,
My phone has lost its service since this morning and it hasn't come back. I've tried airplane mode and back, rebooting, LTE-5G shifting, and everything I can. Still no service with at all. It's really frustrating. Need help ASAP.
djferens
Hello,
No, I'm in Ontario.
Rebooting the phone worked yesterday, but I experienced the same issue again today.
@djferens wrote:
We have been having the same issue on two different devices, both with Public Mobile. Turning on airplane mode on and off temporarily fixed the issue for me as well yesterday, but I had no data connection again this morning as well.
hI @djferens
are you in Winnipeg area? there is active outage now
And check the Telus outage map and see if your area has any current outage
of course, try Reboot phone and Reset network settings again
djferens
Yellowmustard
I noticed the same issue since last night. Turning on and off airplane mode seemed to work for me!
hi @hoda799
there was a data problem in some area yesterday but is now fixed.  Try Reboot phone and click Reset network settings
hoda799
My Data doesn't work since yesterday. what's going on?
Alot of people have same issue over the last 2 days. No announcement has been made regarding any outages or issue. Try turning airplane mode on and off.
Message them to reprovision your account for you.
If the chatbot doesn't work, message them directly at the link below.
Sansan
Seems like an outage on Public Mobile's side. Message them to reprovision your acct for you.
Halifreaks1
My family have all lost access to their data.
I'm wondering if there's any acknowledgement from Public Mobile /Telus?  I just want to know whether the issue is being addressed.
Thanks
