01-26-2022
07:29 PM
01-27-2022
09:04 AM
Dunkman
Hi I was talking with a friend with iPhone 13 pro max than it went silent so I got my wife which seating next to to call me but my iPhone doesn’t ring and she a message ( warning this number is no longer in service
and I it showes I still have over 40 calls left
thanks
01-26-2022 07:30 PM
What does your self-serve say? And when was your last payment?
The only way incoming calls would be shut off would be if your account is suspended due to non-payment.
01-26-2022 07:31 PM
January 13/22
01-26-2022 07:32 PM
No matter plan you have unlimited number of incoming calls.
There is no such thing as '40 calls left' (unless it is some kind of weird old plan...) but it could be 40 minutes left if you are on $15 plan.
Reboot your phone, try turning airplane on/off. It could be temporary cell tower glitch.
01-26-2022 07:32 PM
01-26-2022 07:33 PM
@tsilva Can you call or text someone? Do you get data service? Log into your self-serve account and verify things are normal including your correct phone number.
_________________________________________________________________________________________________
If you need to contact PM Customer Support Agent, create a Ticket.
New Here? - Check out Knowledge Base Articles to learn more about Public Mobile.
01-26-2022 07:34 PM
But it shows that I have used 53 calls out of 100
01-26-2022 07:34 PM
@tsilva What plan are you on? If on a limited minutes plan perhaps you've used up your available mins and need to purchase more at $5/500 Canada wide.
You could also try rebooting the phone first too or toggle airplane mode on/off.
01-26-2022 07:42 PM
@tsilva @ wrote:But it shows that I have used 53 calls out of 100
That must be 53 mins out of 100.
01-26-2022 09:09 PM
Please note that your calls are in minutes out of 100 minutes and not number of calls.
Best that you check on your Self Serve account under View My Usage for the times of each calls.
You can add-on additional minutes or download a WhatsApp as a backup for free wifi calling & texting.
