Cannot switch from telus to public mobile
lwangars61
Unlocked from Telus. Still cannot access my Public Mobile network.
@lwangars61  - did you complete the Public Mobile SIM card activation process either in-store or online, found here: https://publicmobile.ca/en/on/portal/activation
If you did complete the activation, then confirm you were charged successfully for this.
Try one or more of the below:
*turn off your phone, then reboot
*removing your SIM, then reinserting it
*go into airplane mode, then going back to regular mode
*reset network settings on your device
*Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
Did you leave the Telus SIM card in your phone to accept the PORT via SMS/text.
If you missed this 90 minute window, submit a ticket via this link to re-initiate the port:
Link to contact Customer Support Agents (CSA) for porting to Public Mobile
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
And you don’t just mean that you are still not receiving calls (number hasn’t ported yet) but everything else works?
AE_Collector
darlicious
@lwangars61
What is your brand and model of phone? Do you see Public mobile on your phone? Do you have any of your services? Calls in/out? Texts in/out? Mobile data?
pkaraa
It should be easier to port in from Telus rather than from any other provider.
check the process here : https://productioncommunity.publicmobile.ca/t5/Get-Support/BE-PREPARED/m-p/112014#M20827
0PX9O4
@lwangars61
Did you get a new number or did you port your Telus number? How long has it been since you activated a new number or ported the Telus number?
And what are you seeing currently when you try to make a call?
