Transferring a number
Sceviour
Not able to transfer number from another server, although other account is still active.  Public mobile account is already activated, but not allowing me to change within my account as suggested...any suggestions?
@Sceviour
Check to see if the number you wish to transfer is eligible using this tool:
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do?lang=en&appname=otherportal
If eligible, try clearing your browser's cookie/cache, or opening a tab in incognito mode, then try again.
If problems persist, contact Public Mobile Customer Support Agents (CSA) to help with your number transfer.
Two methods to reach them here: https://www.publicmobile.ca/en/on/get-help/articles/contact-an-agent
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
Meow
You have to initiate porting at other provider. Leave your OLD SIM in the phone; you should receive SMS from old provider and reply YES to authorize porting.
darlicious
@Sceviour
Are you getting an error message?
To port your number in use the following:
  1. Full name on account.
  2. Phone number.
  3. Telus account #.
  4. Alternate phone #. ( optional use any phone #)
@0PX9O4
Do you own a staffing agency supplying outsourced employees for pm?
will13am
@Sceviour , please ensure that you have followed this help article on completing the number transfer process.  Note that it is crucial that you keep the old SIM card in the phone so that you can accept the number transfer from the old service.
https://www.publicmobile.ca/en/on/get-help/articles/choose-your-phone-number
0PX9O4
@Sceviour
You can always just send a private message to CS_Agent with your account details (both current PM as well as the account that you want the number ported from). They will be able to set it up for you.
