02-03-2022 10:09 AM - last edited on 02-03-2022 08:52 PM by Dunkman
Hi, new activation.
set up complete and confirmed
number transfer complete and confirmed
payment complete and confirmed
cancellation of previous provider complete and cnfirmed
****did not recv. pin number for new SIM card. ( 4 days waiting for email)
02-03-2022 07:04 PM
@JMAlbert : Then I think BKNS27 is close. Is this a Samsung phone? If so then the phone seems to be locked to a provider. They have an excellent online chat to get a code to unlock it.
02-03-2022 06:56 PM
i tried 1234 not working. PM service never worked at all. “network lockedSIM card inserted”
02-03-2022 01:05 PM
not 1234
02-03-2022 01:01 PM
Hi @JMAlbert
Where to find your PUK (publicmobile.ca)
they not send by email
Check your Community private message inbox (click on the envelope top right of your screen)
02-03-2022 11:30 AM
What does your phone indicate?
Are you using a Samsung phone? If you are, you need to contact Samsung.
If it ask for a PIN for the SIM, try 1234. If that fails, contact a CS_Agent for the PIN.
02-03-2022 11:24 AM
Contact PM support for setting up an PIN by creating a ticket via chatbot or by sending a direct msg to CS_Agent.
02-03-2022 10:56 AM - edited 02-03-2022 10:57 AM
PM SIMs do not ship in a locked state so there is usually no PIN. You can choose to set a PIN and lock your SIM yourself on your phone. If you attempt to use the wrong PIN (set by yourself) too many times to try to unlock your SIM, you will then need a PUK. PM can provide this PUK if you contact them as has been stated above.
02-03-2022 10:18 AM
if you do not have a pin number, contact CS_agent and provide them with the following to authenticate yourself.
02-03-2022 10:11 AM
@JMAlbert PIN number for the new SIM card?
or you meant the 4 digits Account PIN?
If you need a PIN number to unlock the PIN, you wouldn't be able to use the PM service as the phone will ask you for SIM pin before it will try to connect to PM network.
PM SIM usually come without the need of SIM PIN. Some people tries 1234, but again, usually the SIM is not lock unless you add a SIM PIN yourself
What exact error message showing?
