01-12-2025
06:41 PM
01-13-2025
01:54 AM
computergeek541
During activation it prompts that the esim was not installed. How do i find my esim number
01-12-2025 09:40 PM
@AdamTham wrote:Thanks htidegnow. They didn't send me a welcome letter with the pr code. The customer service rep was not helpful. All he told me was to go get a physical sim.
The customer service rep asking you to get a physical sim doesn't mean that the rep wasn't helpful. If your phone can't use an eSIM, getting a physical sim is the only option. The only thing that I'll agree with you on is that the rep should have have offered to send a physical sim, but that can take a couple of weeks to arrive, so getting it at a Telus store or through Amazon is probably faster.
01-12-2025 08:05 PM
01-12-2025 06:47 PM
hi @AdamTham
why you want to find the esim number? shouldn't you try to install the esim instad
check the Sim Manager or Settings-> Cellular and check if the Public Moble esim is there. If not, check PM welcome letter, it has a QR code to scan and install the esim
if that does not help, as PM to check, you can submit ticket by direct message:
