bought phone ups return to sender
Kosh
I've order a phone.it was sent to pobox and sent back to you. Need to send it to another address
Order 322609
cellphoneuser1
Order 322609
Refund will be automatic. You don't need to do anything. To get your phone, you need to buy again.
HALIMACS
I guess the first question I'd have, @Kosh , is was the PO Box that it was sent to the address on the initial phone order?
hi @Kosh  please open ticket with PM CS agent and arrange for return and refund.
at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
Meow
Contact agent to confirm they received phone back. Then talk to them to send you the phone to correct address.
@Kosh @Contact support
Getting help from agent
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get
Or get help right here in the community
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
