Problem using data
sclan
Hi Friends,
I recently got my dad to switch over to PM. He's able to receive and make calls, send and receive text messages, but data is not working for him. We've tried changing the settings mentioned here. Still not working. Any thoughts on how to get the data working?
9 REPLIES 9
@sclan happy that works...and you are back online!!!
sclan
This worked! Thank you so much!!
@sclan
make certain he still has data....
Hi @sclan
Please try Reset All Network and it will usually work
pmbc
Tried a full on reboot of the phone?  You have data left on the plan?
sclan
I guess that would help... LOL
It's a Samsung Galaxy 6
statusquo
His data on too?
@sclan what brand and model is your phone?
you can first try to Reset All Network
If Android, try to update the APN  to match the following
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
         or    default,mms,agps,supl,fota,hipri
           (might need to include dun for hotspot)
APN protocol: IPv4
APN roaming protocol: IPv4
APN enable/disable: APN enabled
                or  Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D
hairbag1
@sclan
what make/ model is the phone ?
