Data Plan Upgrade request
Vb7
Hi,
I'm on the $25 plan with 25GB 4G. Is there a way to switch to 5G without paying more each month?
Thanks
2 REPLIES 2
@Vb7 wrote:
Hi,
Thanks
Hello @Vb7
No. If you wanted a 5G plan, you'd have to upgrade and pay more. In all honesty though, and of course, this is just me, 100mbps is more than enough speeds. Yes, 250mbps would be nice but...  seriously. You have an amazing plan. I'd keep it and never let go!
hairbag1
@Vb7
you'll have to look at your plan menu in your account to see what's available for you. Probably gonna cost a bit more but if you need the speed, might be worth it.
