01-08-2022 01:57 PM - last edited on 01-08-2022 05:58 PM by Dunkman
I have set up account and can log in but wont let me submit a ticket
01-08-2022 02:45 PM
yes, the ticket system is still in holiday mode and having trouble for past few days.
Meanwhile if you cant log in then use forgot password and as this is a new account creation then you must have the right email id so use that and reset the password to log back in.
Direct msg to CSA_Agent is always an option. If the above mentioned method can get you in then you dont have to wait.
01-08-2022 02:05 PM
As our friend @Anonymous has already pointed out, you'd need to get in touch with an agent by sending a private message here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
01-08-2022 01:59 PM
close all Browser and do clear cache and cookies for any Browser,
and try open one Browser incognito mode,
and try Forgot your password visit Here link, and enter your email address,
check your email spam,
or you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to
them can solve your issue, they are nice Service Team they will help you 100%.
and them will reset for you,
Here’s How To Contact Customer Support Agent
Good Luck....
