01-04-2025
04:18 PM
01-04-2025
08:49 PM
computergeek541
I understand PM agents are busy with the influx the new account recently added.\
I've recently sent in two tickets to change a plan that I'm not able to do on my end.
Sadly I don't have confirmation of the ticket numbers as I haven't been emailed them on my end(I know I should have screenshot both of them).
Just wondering on a timeline on when I'd received a response.
01-05-2025 01:40 PM
I never PM'd the agent directly. Sorry for the trouble guys. I rarely do it so totally forgot that was an option.
01-04-2025 08:36 PM
Yup no response. I think it's been 4-5 days at this point.
01-04-2025 06:14 PM
@SC123 The envelope is not there for everyone. I never see it either. Instead you need to tap your avatar to the right of the bell icon and there'll be a drop down with Messages. It's too bad there isn't an indicator on the avatar that there is something in Messages, same as there is on the envelope.
01-04-2025 05:52 PM
funny enough I'm missing the envelope at the top
01-04-2025 05:08 PM
@SC123 I've recently sent in two tickets to change a plan that I'm not able to do on my end.
If you mean you want to change to a plan that doesn't appear in your account's "change subscription" then that usually means you aren't able to get it. Specific plans are offered to specific customers now, unfortunately.
01-04-2025 04:27 PM
hi @SC123
did you check the community inbox
if no reply, message support again and ask for update
01-04-2025 04:20 PM
@SC123 wrote:I understand PM agents are busy with the influx the new account recently added.\
Hey @SC123
Check the top right corner of the page.
You'll see the envelope there with notice. If they still haven't responded, send a 3rd request and in the subject line enter ESCALATION 3rd response in (how many days) without response.
