Puk unlock code
Hankrowdy83
Can anyone help me with a puk unlock code?
@Hankrowdy83 wrote:
It says. Sim card locked. Enter puk unlock code. Contact your service provider for details
@Hankrowdy83
You  will then need to contact customer service agent as described earlier.
Hankrowdy83
Dunkman
@Hankrowdy83
What is the exact message showing on your phone?  There are different unlock codes.
From another thread:
SIM network PIN blocked. Enter SIM network PUK."
- This is asking for Samsung's "master code" - I got this after entering the wrong code for the message below too many times. Samsung and/or your previous carrier can give you this.
"SIM network unlock PIN"
- This is asking for your previous carrier's unlock code - just contact them with your IMEI and they'll give it to you easy peasy. If you enter this incorrectly too many times, you'll get the error message above.
PIN unlock key (PUK) is a SIM-specific code used to prevent unauthorised use of a SIM card.
The PIN (Personal Identification Number) enables secure access to the SIM card and network. It is provided with your SIM card.
    • If the PIN code is entered incorrectly 3 times, the phone is locked (except for emergency calls) and requires a PUK (Personal Unlock Key) to reactivate it.
    • Once the PUK is recovered and validated, you will be asked to choose a new PIN.
Caution! If the PUK is entered incorrectly up to ten times in a row, the SIM card becomes unusable.
Chalupa_Batman
Hello @Hankrowdy83
You will have to reach out to a CS Agent to get this.
