Ticket?
414tech
What is a ticket when I asked to submit one in?
2 REPLIES 2
eddieO
@414tech because there is no live agent to speak with, issues get resolved by opening a ticket. Below are the links:
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
hairbag1
@414tech
that's how to start communication process with PM Customer Support...BUT...let us know what your issue is and we can give you some guidance.
