01-13-2025 02:55 PM
Hi,
I need to reset my wife's account that has been locked out, i try resetting the password everyday but it won't let me reset it, it keeps going into the same screen.
Also, i forgot the email address that was used to open his account, how do i go about figuring out how to reset it.
It is really frustrating sometimes trying to reach some support specially when we can't login to submit a ticket in the first place and there is no phone number to call in order to reset the account. We are thinking of moving all of our 4 services to a different provider. Your prices are not competitive as they used to anyways.
Thank you
Ramy Nissan
01-13-2025 03:22 PM
Please keep in mind that your PM accounts must be active to port out. If not then you can’t port out to another carrier.
Best to contact a CS_Agent to access your parent’s account.
Also make a note of all emails and passwords so you won’t have accessing issues in the future.
01-13-2025 03:03 PM
@Rams123 try reaching out to a support agent but you will need to open a ticket to do so:
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
