Update I got my fone working... Thanks for everyone who helped
Icey7860
Hello, I'm new here but since yesterday I'm unable to receive any txt messages I have tried everything.. any help or advice would be appreciated.
13 REPLIES 13
@Icey7860 wrote:
Nope this just happened 2 days ago now my calls go straight to voicemail too..
@Icey7860 curious, what model phone do you have?
darlicious
@Icey7860
It's better if you can put your Sim card in another phone and text or make a call but if not even the second Sim slot of dual sim phone helps otherwise remove the Sim card for 10 minutes then reseat it and reboot your phone.
HI @Icey7860   are you in Alberta or Sask?
They have voice (and text?) problem 2 days ago
Try to reseat your sim card with a reboot
Icey7860
darlicious
@Icey7860
Did this problem occur after renewal?
Icey7860
Hello, I don't have a iPhone I'm on Android
@Icey7860 wrote:
Nope can't receive any txt from friends or any business
@Icey7860  -
Did you activate with a new number and are you an iphone user?
If so, deregister the old number on the iphone: https://selfsolve.apple.com/deregister-imessage/
And set up your new phone number On your iPhone:
  1. Go to Settings > Messages and make sure that iMessage is on. You might need to wait a moment for it to activate.
  2. Tap Send & Receive. If you see “Use your Apple ID for iMessage,” tap it and sign in with the same Apple ID that you use on your Mac, iPad, and iPod touch.
  3. In the "You can receive iMessages" section, make sure that your phone number and Apple ID are selected.
  4. Go to Settings > FaceTime and make sure that your phone number and Apple ID are selected in the "You can be reached by FaceTime at" section.
EDIT, did you try a reset of your device's network settings in the 'everything' you tried? If not, try that and see if texting works.
Icey7860
Thanks for all your help Softech
@Icey7860   Text from friend should work almost immediately (if any delay would be less than 24 hours)
Text from system could take as many as 7 days to work
For your situation, I suggest you to first try  reboot your phone, then click "Reset All Network"
If it still does not work, try your sim card in another phone if you have a one around
If that does not work or you have no spare phone to try, time to open ticket with PM support, they can reprovison the sim and should be able to get it working again
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
Icey7860
@Icey7860  do you not able to receive 2FA text (system text), like those security code from signing into bank sites?   Can you receive text from friends?
Icey7860
I can receive calls and able to send texts but just not able to receive texts.. it's weird.
@Icey7860   did you just join PM and did you request porting in your phone number?
can you confirm if you can recieve incoming calls?  I suspect you might not be receiving incoming calls as well
if you ported in your number, the porting request could be "stuck".  There is a number you can call to confirm the status.  Will message you the phone number.  Please check Community inbox
