3 hours ago
New Umidigi phone. Used Public mobile instructions to setup APN. Phone connects to the internet showing LTE connectivity but no internet. Any ideas? Slane
3 hours ago
@Slane, found this thread from last year that seemed to help another Umidigi user:
3 hours ago
Did you check if your phone is compatible with PM?
Does other services work? Calls/sms?
Unfortunately it is never good ide to buy not leading brand name phone no mater features.
3 hours ago
HI @Slane
Umidigi might not have the proper band to connect. What exact model?
did you try connect to 3G?
3 hours ago
Make sure OS is updated Try Reset All Networks on your phone.
