08-09-2024
03:08 PM
08-09-2024
03:56 PM
computergeek541
08-09-2024 09:31 PM
08-09-2024 05:47 PM
here's another provider for travel in Europe...I found it in RFD's....most contributors have a positive experience even in Netherlands.
https://mobimatter.com/travel-esim/sparks-europe-usa-20+5-gb-free-esim?destination=europe
08-09-2024 05:07 PM
As per below or above, depending on how you set your view... PM is only useable in Canada and the US.
You can look at https://www.airalo.com/ for affordable data plans and then download an app like TextNow. You can pick a local number and is free calling and texting. You can use this VOIP programs via WiFi or on a data only SIM card.
08-09-2024 03:13 PM
@JudyR, no roaming options outside of Canada and U.S. If you have access to WiFi you can use apps like WhatsApp, TextNow or other similar apps.
08-09-2024 03:09 PM - edited 08-09-2024 03:10 PM
@JudyR No sorry PM only has roaming in the US , best to get local pre paid SIM card Europe
