09-13-2024 08:37 PM
My current subscription in picture below. Is this means my data will work in USA?
Plans
09-14-2024 02:24 AM - edited 09-14-2024 02:27 AM
@Chalupa_Batman wrote:Hello @Dyboypogi
Yes. Your data will 100% work... as long as your phone has VoLTE enabled. You may have to go into your settings and turn off automatic and pick T Mobile and also turn on data roaming then reboot. Then you should be good to go.
For data to work while using the service in the US, the phone phone does not have to be VoLTE capable. VoLTE is unrelated to the ability to use data.
09-13-2024 09:22 PM
Yes, but it's not just data, it's also phone calls and texts.
09-13-2024 08:41 PM
Yes you data will work in USA and Canada up to 50GB without any extra charge, but once you use all of your data(50 GB), you will not be able to use data anymore till your next renewal cycle.
09-13-2024 08:38 PM
Hello @Dyboypogi
