03-17-2025 12:00 PM
03-17-2025 12:57 PM
Try airalo esim. Good luck.
03-17-2025 12:02 PM
Great. Thanks
03-17-2025 12:02 PM
@Janetbmac outside of Canada, Public Mobile only has roaming for USA and Mexico. You will need to either get a travel eSIM, a local SIM to the region you are visiting, or rely on Wifi
