Network Connection in USA drops every 2-5 seconds Constantly. Works fine in Canada
NandanFozdar
Hi folks.
I have a USA/Canada plan and everytime I visit the US, the network connection keeps dropping and reconnecting every 2-5 seconds. Happens constantly for days which makes the phone pretty useless. Will get the occasional text message but no data or voice.
Tried the same SIM in my wife's phone and a spare phone and the same thing happens. My wife's phone has the same PM plan and her PM SIM on her Phone works fine.
Is this is SIM issue? I travel to US often and not having a working phone is very stressful! Any solutions please?
DennyCrane
AT&T 5G has been problematic in past. If this continues, try forcing the phone to 4G. Or if that doesn't work, change it from Automatic and manually try T-Mobile, AT&T, then Verizon until you get a solid connection.
@NandanFozdar
It sounds like it could be related to the AT&T or T-Mobile network.
Did you try manually switch to the other network (AT&T to T-Mobile or T-Mobile to AT&at) and see if it is still an issue?
@NandanFozdar wrote:
@Handy Thanks for the help. Her SIM worked fine in my phone which got us through the trip but stressful not having access to my own phone number. How do I ask support to refresh my account/SIM? And how do I get them to send me a new SIM with the same phone number? Any way to find out if things will work before making another trip? 🙂
Click the orange ball on bottom right sid eof page to start process of Customer Support. Give them a brief description of your experience. Give them your account number, cell number, PM pin number, name on acct..etc.
Could be they just need to reprovision your acct.
NandanFozdar
@NandanFozdar  That’s strange , can you test her sim in your phone ? If it does t work it might be your phone and oddly the spare one too . But if it works then yes I’d say it’s sim/ account issue in that case maybe try resetting your network settings or ask support to re fresh your account from their end . If still same maybe get new SIM card and cross your fingers
