2 hours ago
I have a CanadaUS plan so does that mean I can use my phone in the US and not have to worry about paying roaming fees
2 hours ago
@RapidRobert75 It should automatically pick correct network for you ,, and that should be T mobile or AT&T and it’s best to set your phone to 4G/LTE not 5G but you can test and try no harm in doing so
2 hours ago
Thanks will it automatically find a network or do I need to do something
2 hours ago
There will be no extra charges so you don't need to worry about that. Also, make sure you connect to a US network to ensure service while you are there. No worries! 😁
2 hours ago - last edited 2 hours ago
@RapidRobert75 YES you got it , that’s correct . It’s true snow bird plan call to and from each country , using talk text and data . The plan has roaming built into it . Just remember to have data roaming turned on in phone setting when in the US
