Change device
PhilipLeung
I have a $15/month plan with a Huawei phone. Want to get a Google 8 Pro with the same $15 plan. How to do it? Thanks.
Mehrm
Do you have an ESIM or a regular SIM card? I struggled with the eSIM and finally ordered a regular SIM card for my phone. With the regular SIM card, you just need to remove it from your current phone and put it into your new one.
@PhilipLeung
Adding to @hTideGnow, power off both phones before swapping the SIM from the Huawei to the Google phone then power on the Google after the SIM has been installed in the phone.
hi @PhilipLeung
thanks to physical sim card, it is very easy.
just take the sim card out from your old phone and insert into the new and it would work immediately
nothing else to do
