09-12-2024
02:01 PM
09-12-2024
03:38 PM
computergeek541
I recently changed my address on my profile, to one without a Suite number on the second line. However, only the first line of the address was updated, with the incorrect Suite number from my prior address still appearing on the second line. How do I get this fixed?
09-12-2024 02:16 PM
HI @ejc
the address on PM account is not being used for anything.
you can try put in suite number first like 101 - 123 ABC street
or you can try to ask PM support agent to update it for you
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
09-12-2024 02:02 PM
@ejc , you should be able to edit your address in the profile tab of the online account. I find that using the app with location permission enabled works best.
