04-19-2024
05:53 PM
04-20-2024
02:24 AM
computergeek541
Using my wife’s phone, In Florida now, have CanadaUS PLAN, no internet. Turned phone on and off, toggled airplane mode.finally did a Network Reset,now unable to make or receive calls.says I’m on AT&Thow to fix, anybody?
Service
04-20-2024 04:10 PM
Manually picking AT&T and switching to 4G/LTE Seems to work!
04-19-2024 10:54 PM
04-19-2024 07:03 PM
Tried this internet keeps dropping
04-19-2024 07:03 PM
Yes
04-19-2024 07:03 PM
Thank you
04-19-2024 06:05 PM
Try changing your phone to 4G or LTE. Supposedly that will work better with AT&T. 5G will work with T-Mobile.
04-19-2024 06:04 PM
HI @RayParker
try connect to T-Mobile first. change the network mode to Automatic and test again the voice calls
if still not working, connect to T-Mobile but change the network mode to 2G and test once more time
04-19-2024 05:58 PM
click this for some info on volte, scroll to bottom to see if yours is on the "whitelist".
04-19-2024 05:57 PM
Did you turn Data Roaming to “On”?
04-19-2024 05:57 PM
Hey @RayParker
Go into your network settings, turn off automatic and choose T-Mobile. Then make sure your your Cellular Data is on and your roaming is on then reboot.
04-19-2024 05:56 PM
make sure Roaming Data is enabled for data to work.
Restart phone. Try selecting either of T-Mobile or AT&T.
Is you phone on PM's volte whitelist ? If not you need to manually select 2G for calling and only T-Mobile....but service will be poor, at best.
