04-20-2024 03:58 PM
We switched from freedom to Public.. sms was working fine. and not.working anymore.. its an Iphone that I have. can you please advise.
04-20-2024 04:04 PM
Public Mobile is dealing with issues when it comes to SMS on Android and iMessages and FaceTime and such. There is no ETA of when it will be resolved. Here is their announcement.
We are aware that some of you are currently unable to successfully use iMessage and or FaceTime features, and we understand how frustrating this can be. Our teams are working diligently to find the cause.
In the meantime, please try troubleshoot steps:
Tap Settings > General > Transfer or Reset [Device] > Reset > Reset Network Settings.
We apologize for any inconvenience this may have caused and will continue to keep you updated.
Thank you,
Keep an eye on this thread as they SHOULD update it when things are fixed.
To Submit a ticket, please click the following link to access the Public Mobile Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type: Customer Service Agent
IMPORTANT INFORMATION: I am not a Public Mobile employee. I am a customer just like you. Please do not send me a private message with your personal information.
04-20-2024 04:01 PM
HI @Umirza
Yes, if only SMS an issue, it is a PM system problem with new activation. Voice, data both work but just SMS is the problem. And with the SMS problem, it will affect account verification. PM is aware of the problem and can only fix the issue one account at a time.
Please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
