07-02-2023 01:31 PM
Phone calls work but txt wont send or receive. Took sim out and tried different phone still did not work. Phone calls work
07-02-2023 02:45 PM
@Deborah1313 wrote:Anyone, just just one person. I cannot receive txtxs as well
Please clarify your response. You can't send / rec texts for anyone OR just 1 person ?
07-02-2023 02:08 PM
07-02-2023 01:56 PM
you cannot text anyone..or just 1 person ? If that's the case, maybe that 1 person has blocked messages from you for some reason. Check to see if you can't successfully text others.
07-02-2023 01:47 PM
Native txting. No changes, google pixel phone. I have tried a different phone and txt wont work as well.
07-02-2023 01:44 PM
Which phone do you have? Android versus Apple?
Does data work?
Might want to try network reset of phone (note: this will erase any saved Wifi settings)
07-02-2023 01:43 PM
if all else fails..send message to CSA to ask for their assistance with your issue...
07-02-2023 01:41 PM
Do you use Native texting app or some 3rd party app?
Something is blocking SMS... did you do any set-up changes recently? Did SMS EVER worked?
07-02-2023 01:37 PM
I have rebooted and also tried a different phone. Phone calls work but txting does not
07-02-2023 01:32 PM
reboot phone once
if you are using Android, try to clear cache
If issue persists, download Google Message, set it has default app to text and it should resolve the issue
