Re: Just ported to public mobile but not receiving calls or SMSs ?
Great
Hi I recently ported a couple days ago followed all prompts I cannot make any calls or texts please help phone number is 647-829-4393
hairbag1
@Great wrote:
Hi I recently ported a couple days ago followed all prompts I cannot make any calls or texts please help phone number is xxx-xxx-xxxx
You should never post your personal info in any forum as anybody can see that info...including the not-so-honourable. You should edit it out asap. Did you reply YES from old network when you requested the port ? Did you remove old sim and install new sim ? Are you using esim or hard sim ? Have you tried restarting your cellphone ?
slusagm
try your sim card on another phone to test.   Ask PM to help if needed.
  Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here
eddieO
@Greathave you tried rebooting your phone after the number porting completed? Also to confirm, did you respond YES within 90 minutes of receiving a confirmation text from your old provider?
HI @Great
this is just the community and we are customers only, remove your phone number
For your problem, ask PM support agent to help.  You can submit  ticket by direct message:
