3 weeks ago
Unable to make international calls despite purchasing (twice) 300-minute call time. It keeps saying to contact Public Mobile.
3 weeks ago
Fongo app quality is poor on the phone
and honest, if I need to pay the add-on to call overseas, I would rather use calling card than Fongo , more portable
3 weeks ago
@Phil_Adelphus I have Fongo for home phone and call quality has been perfect for me and those that I have called have sometimes commented that I sound crystal clear
3 weeks ago
@slusagm but using Fongo to call Switzerland is not free, either, you need to pay credit to call overseas, but true, that is an option
True but neither is a PM add on or LD calling card. Last time I bought a LD calling card it expired before I had used it all. Fongo world credits start at $5 and don't expire until you've used it up, and their rates list Switzerland as from $0.02. Whether the call quality will be good enough is another matter although it seems to be better lately than it used to be. The dialpad does tell you how much the call will cost before you initiate the call.
3 weeks ago
3 weeks ago
@bluebelanger Another option is to download a voip app like Fongo from the App Store/Google Play depending on phone and use that to call (it won't be your PM phone number though).
3 weeks ago
Switzerland is not on the calling list, no one can help with that other than get a refund with the add-on you purchased
if you need to call Switzerland urgently, get a LD calling card from store rather than wait here for nothing
3 weeks ago
@bluebelanger Public Mobile does not offer any phone number to call for support, it's all done online but you can reach a support agent by opening a ticket. They will message you back in your community inbox and will likely work out a refund or credit for the add-on that you cannot use.
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
3 weeks ago
Trying unsuccessfully to find a phone number to call a service agent and cancel the 2 purchases of 300 min. Please assist. I am so disappointed that I cannot call Switzerland through my phone.
3 weeks ago
@bluebelanger not to worry, your ticket is not closed so you can continue the thread/discussion. Marking a solution means that you found a specific post to be most helpful but doesn't close it.
3 weeks ago
@bluebelanger Since Switzerland is not on the long distance list of countries you will need to reach out to a support agent and ask for a credit/refund. Through Public Mobile there will not be any other options for calling Switzerland. There may be other options, but you will need to search online for those as I'm not familiar with any personally.
3 weeks ago
Sorry it is not a workable solution. I assume that by typing there, a solution to call Switzerland wound be provided. I did not want to close the issue.
3 weeks ago
I meant the funds for the 300-minute international calls appear to be on hold. Why?
3 weeks ago
This is urgent. Funds also appear to be on hold until 24 and 25 January. I need to make those calls today. Offices in Switzerland will close in a few hours.
3 weeks ago
From Canada to Switzerland
3 weeks ago
Are you calling from Canada and which country are you trying to call?
3 weeks ago
@bluebelanger which location are you looking to call? Please check if the country you are trying to reach is below:
Long distance addon
