01-17-2025
12:10 PM
01-17-2025
05:51 PM
computergeek541
I subscribed to the 23 dollar plan. I chose the esim route but that didn't work out so I bought a sim card. I chose a new phone number but my phone isn't showing a phone number. In setting it shows there is a public moble card in the phone but now phone number and the phone is now useless. Yes, I did a factory reset as well.
01-17-2025 12:31 PM
Ok I'm done I'm just going to go to another carrier. This is the worst experience with any company I've ever had.
01-17-2025 12:23 PM
if Reset Network settings does not work, check if you can edit manually phone number on the settings
01-17-2025 12:20 PM
Yes I just tried and it says phone number unknown.
01-17-2025 12:15 PM
It's a pixel 3a
01-17-2025 12:14 PM
what phone is that? iPhone?
Usually a Reset Network Settings will fix it
but make sure you have latest iOS too
01-17-2025 12:14 PM
Have you tried rebooting your phone? Another thing to try is to place the SIM card in another device to see if it works there. If you want to reach a support agent that might help get things working faster as there might be something on their end that is needed.
