12-10-2025
07:26 PM
12-10-2025
10:37 PM
computergeek541
I got this number to have as a work phone, it worked until yesterday and today, now when my work tries to send the call forwarding to my phone number, they recoevw only a busy signal. The phone number itself accepts phone calls from other numbers without issue.
12-10-2025 10:36 PM
@RhiannonGeorge wrote:not sure why my S10 suddenly has "disconnected" as the network state, is there a solution to that?
That isn't an actual issue unless you're trying to use mobile data. Android will show that as disconnected whenevever mobile ddata isn't being used. As you're using Wi-Fi, it's supposed to say that.
12-10-2025 10:17 PM
Reboot phone and click Reset Network Settings
And try the PM sim card on another phone and see if it works. And if you have another sim card, try it on that Galaxy S10 as well
12-10-2025 10:03 PM
12-10-2025 07:46 PM
You could reset your phone networks to see if that will help.
