Phone calls not working
Sien
I just activated the account yesterday.  And I've got some situation here. Phone calls doesn't work. The system said 7B1 and call customer service every time when I try to make call.
Thank you
Sien
Text & data are fine.
And able to receive calls. Just can't make the call.
Yes, I do add 1 in front of the area code.
Dunkman
@Sien
What about texting?  data?
Are you able to receive calls?
Maybe try add prefix 1 in front of area code.
@Sien
  • first try to reboot the phone
  • If that does not work, change the Preferred network type or network mode to 3G only or WCDMA only and see if it works
  • Try to click Reset All Networks and see if it helps
  • and do you have another phone to test the PM sim ? just to make sure it is not a device problem.  Also, that can force a sim card re-provision and it could resolve the problem
  • Also, try the phone in another area if possible, it could be just a local network outage
if those do not help, it is likely a sim provisioning issue, easy fix for PM, just message them
