Text is not working and can’t call any contects
Zoe_martin
we just joined Public Mobility yesterday and now our text messages and calling contacts are not working
8 REPLIES 8
Immune
As others have suggested first re-boot your phone. Then make sure that your phone settings are correct---- in settings click on your message app and make sure that you enable "Send as Text Message" --- "MMS Messaging".
If the problem persists then you have no choice but to get help from CS.
submit  ticket by direct message:
@Zoe_martin
Have you tried rebooting your phone?  Next is to do a network reset of phone (note: this will erase any saved Wifi passwords).
P.S. I will combine both of your duplicate posts.
@Zoe_martin  Sounds like account set up issues no worries support can help
send  a  private message   To CS_Agent
Zoe_martin
We signed up with you yesterday and our text and phone won’t send.  I do receive a text message and receive a phone call. Just can’t send anything
Pat301
@Zoe_martin did you have your old provider's sim card plugged in after the port in was done into public mobile. If you have your old provider's sim card plugged in still try using the public mobile sim card. If the New public sim card is still not working reach out to the chat bot and make sure that you have the serial number of your sim card noted down somewhere so that they can trouble shoot.
hi @Zoe_martin
but you can receive calls? or cannount make outbound and not receive inbounds at all? does the phone showing connected to PM network?
if you are not connecting, or unable to make outbound calls or text, ask PM support to check.
you can submit  ticket by direct message:
eddieO
@Zoe_martin have you confirmed that number porting completed? Try using the old SIM card (from previous provider) to see if it's still calling out/receiving calls, if it is then porting is not complete. As part of porting did you get a text from the old company asking to confirm porting? If so, did you respond YES within 90 minutes?
if you are still having issues you will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
@Zoe_martin  Try rebooting the phone first , is still no luck get support to help
