Call from Mexico to Canada not working with new plan Canada-usa-Mexico
Empty
Try to call to Canada from Mexico and operator told me call can't be done???…I have an iPhone SE  and canada-usa-mexico plan
Kev7
00+1 <7digits> works!  I’m in Puerto Vallarta.  This was driving me nuts thanks.
fastfred
Thanks so much man...IT WORKED!!...was getting pretty frustrated with the ARTIFICIAL intelligence..
Empty
Thank you !!! Gracias!
hi @Empty
there seems to be many different way to do it, try them all
  • 001 <area code> <7 digits>
  • 00+1 <area code> <7 digits>   (key is to use a + in between the 00 , actual dial the plus sign, it does not mean concatenation)
  • 00 1 <area code> <7 digits>
slusagm
try +1 and then the 10 digits (the + 1 is plus sign and then 1)
